Anyone tried Nordost Blue Heaven or Red Dawn Speaker Cable
dubber
Post by dubber »
Never really been into speaker cable, just have some copper wire (well Kimber 8TC) at the moment, but a few have mentioned these Nordost cables are the bees-knees. Anyone have any experience of these?
Re: Anyone tried Nordost Blue Heaven or Red Dawn Speaker Cab
I have not used the Blue Heaven or Red Dawn but I do use the Nordost Flatline speaker cable. It is a bit bright but my system needs that so the combination works fine for me.
I don't know if they're "the bees knees" but they are very good, very competent cables. But there are a lot of very good, very competent cables out there.
JFK
Post by JFK »
Hi Ivor , The right man in the right place , looking for some Speaker cable to replace to very short run of unterminated Nordost Super Flatline , its just a tad too bright for my B&W M1s - Any recommendations for something a little less bright ? Would only need about 3 metres in total
JFK wrote:Hi Ivor , The right man in the right place , looking for some Speaker cable to replace to very short run of unterminated Nordost Super Flatline , its just a tad too bright for my B&W M1s - Any recommendations for something a little less bright ? Would only need about 3 metres in total
have you tried standard mains cable - solid copper core should soften out the brightness and if you don't like it well.... it's cheap and cheerful.
sdiesel77
Post by sdiesel77 »
For my B&W, I have now a pair of Chord Epic Twin which I really like :p
