Power distributor block / extension lead
For Sale/Wanted
Maciej
Post by Maciej »
Hi All,
I am looking for better quality than widely available power block / extension lead with 6 or 8 UK outlets.
Let me know if you have something decent laying around and would like to sell.
Thank you
Maciej
Re: Power distributor block / extension lead
Richersounds.ie in Belfast usually have a good range of products at sensible prices. I haven't browsed in quite a while but worth a look.
Maciej
Post by Maciej »
Ivor wrote: Tue May 07, 2024 10:45 pm Richersounds.ie in Belfast usually have a good range of products at sensible prices. I haven't browsed in quite a while but worth a look.
thanks Ivor,
I was also looking at their neighbors offer from KRONOS.
TITAN audio
https://www.kronosav.com/en-ie/collections/titan-audio
Kind regards
Maciej
Interesting.
Maciej wrote: Wed May 08, 2024 10:20 am
thanks Ivor,
TITAN audio
Kind regards
Maciej
I would definitely recommend Titan Audio. Preferably direct. I use them myself.
https://titanaudio.co.uk/collections
and of course Cloney have the well regarded AudioQuest units,,,,
https://www.cloneyaudio.com/store/power ... est-series
Post by james »
I bought (years ago pre Brexit) from Olson
https://olsondirect.co.uk
Got a 6 way metal distribution board.
Quite happy with it.
No idea what the situation is post Brexit
I understand Olson is not hifi but industrial
Brutus1968
Post by Brutus1968 »
years ago I decided to go for the DIY route and made a couple of extension leads with solid core wires and star connections. I simply used good quality industrial components.
Best
Max (spin the black circle)
I’m impressed!
Maciej
Post by Maciej »
Looks impressive.
All my power cables are UK, and I was always thinking to get rid of them, and replace with Schuko version. Only to run UK power cable from the wall socket to Schuko power distributor block, and then use Schuko cables to each device.
Schuko plugs do not have a fuses like UK plugs. I do not see much point of using additional fuse if your equipment has already a fuse in the power inlet socket.
