Static shocks
stigpepper
Static shocks
Post by stigpepper »
Hi,
I keeping getting static shocks from my equipment especially the volume control on the amp. It is a wake up call each time it happens but is it something I should be worried about.
Re: Static shocks
A static charge is normally transferred from you to the device and can be large enough cause damage.
Several years ago anything metal I touched gave me a static shock, door handles, the car, Hi-Fi system...
I traced it back to a specific pair of shoes, they got binned, I haven't had a problem since.
It might just be a case of changing your footwear, or similar, did you get a new carpet?
But if it’s not, then I would be sure to check the system has a sufficient earth.
Re: Static shocks
If you have a multimeter you should check for continuity between the knob and the earth pin of the plug, and between the case and earth pin. If there is, then your amp is earthed properly and the problem is probably you being earthed through the amp - like in dereks case.
Re: Static shocks
Derek wrote:A static charge is normally transferred from you to the device and can be large enough cause damage.
I have that with a particular pair of Hush Puppies. I don't use the hifi if I'm wearing them!
stigpepper
Re: Static shocks
Unfortunately I do not have a multimeter to test the amp but I will keep an eye on my footwear. It could be the Liverpool slippers I got for my birthday.
Thanks again for the advice lads.
Rocker
Re: Static shocks
Post by Rocker »
Liverpool slippers?????
Beware of a thin chef!
stigpepper
Re: Static shocks
Don't knock them rocker, they may blow up my hifi but at least I'll never walk alone while I'm wearing them.
