Headphone amplifier kits
Frankie Lee
Post by Frankie Lee »
Having successfully upgraded my turntable motor I'm tempted to try some more hi-fi DIY. Anyone got any experience of these? https://bottlehead.com/?product=crack-o ... lifier-kit
They look ideal for a first project, just curious if anyone has any other recommendations.
Re: Headphone amplifier kits
Bottlehead have a great rep - just be aware that you are most likely working with high DC voltages that carry specific risks different than those that AC presents.
What about looking at the one with the toshiba mosfets viewtopic.php?f=8&t=4319
Also worth taking a look on diyaudio and seeing what kits are hot at the moment.
yea do this one is relatively simple and cheap
frd1996
Post by frd1996 »
Fran wrote: Sat Sep 16, 2017 10:20 pm Also worth taking a look on diyaudio and seeing what kits are hot at the moment.
Maybe not super hot at the moment, but worth noting: Gainwire mk2 and Salas DCG3
http://www.diyaudio.com/forums/solid-st ... e-mk2.html
http://www.diyaudio.com/forums/analog-l ... phone.html
I built the Gainwire mk2 and the sound is really good. The design may seem complex, but it has this advantage that it does not require expensive/exotic parts.
DCG3 is definitely on my todo list.
F
randytsuch
Post by randytsuch »
Heres a list of hp amps and sources for you
https://www.head-fi.org/threads/list-of ... rs.537398/
I've never heard the crack, but was thinking about buying one before. Based on reputation, you could do worse.
nice thing about bottlehead is they include cases/chassis for their kits. If you build stuff, you'll find casing is the most time consuming and usually the hardest part of the build.
Randy
Nice link, a keeper me thinks.
mossym
Post by mossym »
i have a 90% complete AMB MK3 at home, almost fully built, but i haven't touched it in 3 years. keep meaning to get back to it but never have. waste really
randytsuch
mossym wrote: Mon Sep 18, 2017 5:23 pm i have a 90% complete AMB MK3 at home, almost fully built, but i haven't touched it in 3 years. keep meaning to get back to it but never have. waste really
I have sooo many 1/2 or 75 or 90% completed projects laying around. My wife is on a cleaning kick, so I'm going to try to either finish or sell or do something with some of my stuff.
Randy
