Wanted Bargain Tuner
For Sale/Wanted
Rayfi
Post by Rayfi »
Hi Folks,
Im interested in a bargain tuner for my mancave in the attic. I have been looking on donedeals, adverts etc for a nice vintage unit but its hard to know what to look for. I know its all internet radio these days and I love tunein and have it running on kodi downstairs though main rig but for the attic a cheap vintage tuner would be rocking. Could anyone recommend something I should be looking out for and being a cheapskate I only want to spend a max of 50-70 Euros.
Do those old tuners just run and run or are they have a high fail rate given their age etc. I appreciate any tips on tuners you may have.
thanks
Ray
Steve
Re: Wanted Bargain Tuner
Post by Steve »
Hi Ray,
I'm not 100% sure if this fits the bill for the type of vintage tuner that you're looking for.
But I do have a Sony ST-261 if you're interested? I believe it's vintage would be mid-90's!
(Seems to qualify for the radiomuseum.org if that's anything to go by!)
http://www.radiomuseum.org/r/sony_fm_st ... _s261.html
Cheers,
Steve
Ha, I was just about to suggest that one as an option to look out for. I have a Denon from a similar vintage (the TU-260) that still provides admirable service and sounds good at home, but soon after I bought it Sony released the above mentioned tuner at roughly the same price. This one not only had RDS, but it sounded as good as if not better than the Denon. I was raging!!
bonenut
Post by bonenut »
hi,i have a yamaha natual sound tuner from the late 70's early eightys.great tuner which i used in my own man cave for years.i had it paired with the matching yamaha natural sound amp from the same era.if your interested in the tuner i could send pics.cheers.
Rayfi
Post by Rayfi »
Thanks for the response lads. I suppose if you could stick up some pics of the Yamaha tuner as Im not familiar and that Sony unit looks great Steve. Im only after a cheap unit as im mainly a cd man and just would like a tuner as an extra option. Today I managed to stream from my google nexus tablet running tunein to a Uplay bluetooth streamer ive connected to my amp and it worked ok. Its a great cheap option if you have good wifi but the attic is unfortunately a wifi blackspot and it kept dropping.
Thanks again
Ray
The other thing is that bit rates on internet radio are often really poor, you'd be better with analogue fm in lots of cases.
bonenut
Post by bonenut »
not able to post pics but its a yamaha t 550.black.send me your email by pm and i could send you a pic when i get home tomorrow.cheers.
