This is for vinyl specialists... I'm looking for a turntable base + arm for my Dynavector xx2-mk2 I bought in the past.
I need your help in finding a turntable model that can fit my budget, around 1600$ (or 1500 euro) or less, and my cartridge.
New or second hand does not matter, DD or belt drive does not matter, simply if you ever listen my cartridge in a not-so-expensive setup or you can give me some ideas on what I should looking for.
What I need is speed and bass control, because on vinyls I listen mainly Progressive Rock, or mainstream rock, no other genres.
My phono preamp is a Lehmann Decade.
My first idea was for Rega RP8 but it is over budget... and I need to save money for the new loudspeakers ;-)
Any suggestion is welcomed, thanks in advance !
-Max
new member needs advice: a good,but relatively cheap,tt
Dgt: MSB Analog,MacMini,Audirvana+,HQPlayer Analog: Technics SL1210mk2, Dyna XX2 Mk2, Lehmann Decade Amp: Spectral DMC 15SS + Spectral DMA 200S2 Spkr: Wilson Sophia 3 Cbl: Spectral UL-38 HD/MIT SL-Matrix 26
Re: new member needs advice: a good,but relatively cheap,tt
Surprised Max none of the TT heads have given you some advice here. Maybe nobody has experience of what you are thinking about. Unfortunately not in a position to offer any words of wisdom here.
I think Project provide good value for money
Hi Max,
You could pick up a very nice, used Linn Sondek for that kind of money. This one features your cartridge.
Terry
Terry
- image.jpeg (85.22 KiB) Viewed 1820 times
@ Terry, thanks for the suggestion, as I can see you have a Dyna too. LP12...speed and bass control? If you say so, maybe I have the possibility to try an LP12.
@HiFiFan, I dislike Projects not for the price/quality ratio but because their catalogue is full of models with the result imho it is hard for me to distinguish one model to the other ;-)
Hi Max,Maz65 wrote:@ Terry, thanks for the suggestion, as I can see you have a Dyna too. LP12...speed and bass control? If you say so, maybe I have the possibility to try an LP12.
I'm using the Audiotechnica AT0C9/III cartridge with a Dynavector P75 MkIII phono stage. I haven't heard your cartridge but have a read of the following thread. It's a bunch of LP12 users on the suitability/sound character of the Dynavector XX2
http://forums.linn.co.uk/bb/showthread.php?tid=10784
Terry
Thanks Terry, you gave me to read for all this evening ;-)
One hour ago I was in the hifi shop close to my house, taking a look on the second hand gear.
Two interesting tts:
1) Thorens TD524, very good state, I have a suspect of arm not in the best state, at 1500/1800 euro, maybe too much but what a superb machine !
2) Heybrook with alphason arm and external power supply for switching speed, mint state, at approx 900 euro
both tt have a new (rebuild) dust cover
any comment ?
any comment ?
- Thorens.jpg (66.93 KiB) Viewed 1753 times
- Heybrook.jpg (99.08 KiB) Viewed 1753 times
I would look at these within your budget: http://www.hifihut.ie/turntables-irelan ... =1000-1500
Or here maybe: http://www.decoaudio.com/deco_audio_turntables.html
Analogue Works, didn't Cybot buy one a while ago? He might be able to point you in the right direction. The certainly would be on my shopping list if I could afford an upgrade: https://www.divineaudio.co.uk/analogue- ... -zero-6563
The Heybrook looks interesting and is at a good price in the condition you described. The TT2 has been criticised for a "boominess" in the bass, a characteristic which could be exacerbated by your cartridge. Have a read of the following...Maz65 wrote:2) Heybrook with alphason arm and external power supply for switching speed, mint state, at approx 900 euro
http://theartofsound.net/forum/showthre ... on-almost)
Maybe your local dealer will let you borrow the Heybrook for a weekend. Failing that he may be willing to fit your cartridge to audition in store.
T
@tweber, thanks for your suggestion I really appraciate it !
@Terry, boomy is the latest thing I need in my analog setup, I prefer to let this turntable in the shop..
