For sale is my modified Thorens TD160 Turntable with Rega R200. Absolute minimum price is €220.
The following mods have been made:
- The turntable has been re-plinthed,
- A new black topplate added,
- The plinth has had an IEC connector added,
- The option to run the tonearm cable to a set of female RCA connectors mounted on the back of the plinth has been added.
- The plinth sits on three large Michell Tenderfeet.
- The Rega R200 arm has been added with the aid of a Rega mount plate.
- The tonearm lift has been removed from the topplate as the rega comes with its own.
- The tonearm has been completely rewired with cardas litz internally, with a cardas base connector and cardas clips,
- The external tonearm wire is mogami high purity copper with vampire rca connectors.
Extras that come with the table are:
- Silicon damping fluid, should you need it in a few years time for the tonearm lift mech.
- A spare belt.
- A power cable.
- Project cork mat
Photos can be see on adverts:
http://www.adverts.ie/home-audio/thoren ... 00/4017489
For Sale: Thorens TD160 Turntable and Rega R200
