Looking for a headphone amp
For Sale/Wanted
DancingPriest
Post by DancingPriest »
Hi all.
I'm in the market for an amp for my HD 650's. Does anyone have something surplus?
Living Room: Naim Muso 2
Re: Looking for a headphone amp
Don't really have anything surplus, but I have a couple if you just want to see how they sound...
Matt
Post by Matt »
I can recommend this http://cgi.ebay.co.uk/DUAL-AMP-portable ... 704wt_1165
Here's a review http://rockgrotto.proboards.com/index.c ... 309&page=1
I bought mine about a year ago as it looked promising and had good customer feed back.
I got the optional op amp upgrade too.
Its rechargeable and can also be run in the house plugged in with its adapter.
The build quality is very good with solid metal casing.
As for the sound, its extremely transparent. I use it with my sony mp3 player playing 352kbps lossless.
I got the amp because the mp3 player sounds very compressed when you try to play loud and use the bass boost. So with the amp, i have the mp3 player at 2/3 volume and use the amp for the rest.
Ive used it with Shure SE210's which aren't great. Bass light. And my Sennheiser HD280pro's which really shine when used with this amp.
Arcam Cd33, Vdh The Integration, ATC CA2, Gotham GAC-2v1 XLR, ATC scm50asl
Yamnick
Post by Yamnick »
Look at that:
http://www.head-fi.org/forum/thread/446 ... -dac-amp/0
I have D1 (upgraded tube & headphone amp OPAMP, You can read about upgrades on headfi).
I think it's very good relation between price and quality - and easy work with high ohms headphones.
If You want listen to that - I'm live in Longford.
Regards.
Frankie Lee
Post by Frankie Lee »
Fran wrote:Don't really have anything surplus, but I have a couple if you just want to see how they sound...
Is that because I cleaned you out? :)
Yup!!
paulb
Post by paulb »
there is a littledot 2 on adverts valve headphones amp....have a look
Those little dot amps are good. I've had 2 of them. Just make sure its not a mk2 + or mk2++
Not a bad price either
DancingPriest
Cheers for the heads up, looks like they sold the day after I got back from the hols.
Ah well, a week in Bologna and Parma with the lads combined with a fondness for Barolo does nothing for one's bank account!
Not to speak of the fact that I'm off to Provence in a fortnight...... Oh lord, don't I know how to plan my affairs!
Did you get your headphone amp Dancing Priest? Thinking about getting HD650's Komplett.ie have them for €270ish which seems fairly good.
Reckon I will need an amp to get the best out of them. I like the idea of a valve amp.
