Hi Folks
Not sure if this is the correct place to put this:-
I have a faulty QED A240 CD amp with the SA (Super analogue) Phono card. - By all accounts a very sweet musical amplifier that compared very favourably against budget Audiolab and NVA at the time (Mid 80's).
see this link for sample description / pics (nothing to do with this seller btw) here:-
http://www.ebay.co.uk/itm/ws/eBayISAPI. ... SS:GB:1123
Bought this on another forum - approx 2 years ago - unfortunately condition was not as described and return costs etc meant that I did not return. Inspection showed that someone had replaced couple or resistors in line to output stage (scorch marks on PCB) - and one channel output is not working.
Output configuration uses triple darlington transistors and are known to blow as a common fault - have purchased replacements but havent got round to replace - these included also.
Was thinking of fixing to use the amp as a phono preamp ( amp has pre out connections as well as headphone socket).
I have received repair schematics from QED so should be an easy fix for the right person.
Have original box and foam inner.
Please PM me if interested - am based in D12 / D18 and travel 32 counties with work.
Free - Faulty Amp - Possible EASY DIY Project to repair
Re: Free - Faulty Amp - Possible EASY DIY Project to repair
Yeah, I'll have a go at it if no-one else wants it...
Hello,
Next in line please...pm sent
