Where's the best place to get photos printed?
We generally get stuff printed using photobox.ie, but I'm not sure they're at the upper echelons of image quality. Any other suggestions?
Re: Where's the best place to get photos printed?
...apart from Fran's darkroom, that is! :)
360dpi in Dun Laoighaire might suit you sir?
Steve Crozier is the guys name, he can print it any which way you want and good quality too. A good nubmer of the photo clubs use him for their competitions etc.
If you want really high gloss, photech.co.uk can do a recreation of a cibachrome print which gives a very high almost wet look gloss. Beware though, its for framing behind glass right away and you need to be very careful handling it.
Thank you Fran. I haven't the first clue what way I actually WANT things printed, but 360dpi certainly sounds like a good place to start.
Rocker
Post by Rocker »
Hand Imaging in Mullingar are tops. Philip or John will sort out any photo printing issues you have.
Beware of a thin chef!
Ta Rocker.
Yes, and Tony Murray in Naas is also excellent... but maybe a bit mroe out of your way.
BTW, I got an "aluminium" print done here from photobox and it turned out really really well. Landscape only I think....
http://www.photobox.ie/shop/wall-decor/ ... ted-prints
jaybee
Post by jaybee »
second 360dpi....
the place is bit of a kip but his work is good...
and its beside your dart si....
jaybee
Post by jaybee »
of course if its a penny....
inspirationalarts on herbert street beside pepper canister....
expensive... like a valve amp... and worth it... like a valve amp!!
Think I'll start with dpi, although I must admit I haven't caught the dart in quite some time...
Peppercanister is within spitting distance of my office, so that's good to know too.
