lead shot
lead shot
Anyone ever used or bought lead shot to tune the bass on their speakers? Where can I pick up some in Dublin and how much can I expect to pay? Any alternative materials besides drying out sand in an oven!
Since the other half is away for the week I've totally rearranged the the place and the speakers are now firing down the length of the room. The difference in sound has been surprising and unexpected. A bit less boom on some recordings which was welcome so I'm thinking of tuning the mass-loading-chamber in the speaker might be worthwhile.
There is going to be all out war when she returns to this.
Re: lead shot
Derek often recommended a shot blast material (I think) for loading speakers. If he doesn't see this I'll give him a shout to post it tomorrow. Incidentally, if using sand buy a few bags of play sand from the Early Learning Centre. It's dry and lime free and perfect for loading.
Personally I believe speakers and stands MUST be loaded. The difference is huge.
Re: lead shot
You won't get lead shot here - nearest is the UK. Last time I looked no. 9 shot was about 50 pounds for 25kg. Plus postage. The shot blast material is good, not as heavy as the shot though. SC grit I think and cheap too. But that stuff is sharp as hell and easy to get everywhere. Make sure you put it in a plastic bag so it's easy to remove.
Re: lead shot
David, you could post a photo of the new layout before she gets back and restores the old layout!
Re: lead shot
Ivor wrote:Derek often recommended a shot blast material (I think) for loading speakers. If he doesn't see this I'll give him a shout to post it tomorrow.
It’s the stuff used to grit blast, it’s a graded copper slag and very heavy.
I don’t remember the name of the place but I know where it is in JFK Ind Est off the Longmile Road. If you like I can pick up a bag. (I won’t really be picking it up I’ll get help).
Re: lead shot
Thanks for the offer Derek but I'll hold off on it for now. I may be looking at a speaker change anyway so it might not be needed in the long run.
