Hi all, ok need help with buying a tv
First of all i be in the UK,
Need it delivered to me and preferably under 350pounds!
http://direct.asda.com/LG-32in-LD-320-L ... lt,pd.html
http://direct.asda.com/TV%2C-DVD-and-Bl ... rtd1=1&fix
Anything of use there?
Or else where?
Please help me buy a tv
Re: Please help me buy a tv
Also it will be for ps3 + blu ray.
Hi I have an LG 42" Plasma and i cannot fault it for anything , even SD pictures are excellent ..
Dont forget you get what you pay for ! If you can fit a 42" - Go for the LG Plasma .. Much better all round
