sold- Parasound 2125 Amplifier
For Sale/Wanted
woodlands
Post by woodlands »
I have for sale a Parasound 2125 Amplifier.
Very Good operational condition.
For sale at Euro 275.
Specs and manual below...
• 125 watts rms per channel into 8Ω, all channels driven
• 200 watts rms per channel into 4Ω, all channels driven
• 200 watts rms per channel into 2Ω, all channels driven
• 400 watts rms bridged into 8 Ω or 4Ω mono
• 35 amps peak current per channel
• Impedance selector switch for 2Ω operation
• Bridging switch for stereo or mono operation
• A/B speaker terminals with individual on/off
• 18dB/octave high pass filter, switchable 20Hz or 40Hz
• Fully discrete circuitry with toroid transformers
• Efficient, low heat design
• DC Servo and relay protection circuits
• Automatic on/off by DC trigger with looping output
• Automatic on/off by audio signal with adjustable sensitivity
• Gold-plated RCA input jacks, loop output jacks
• Heavy duty 24k gold-plated 5-way speaker terminals
• Rear-mounted gain controls; ground lift switch
• Standby, channel status, high temperature indicators
• 2u chassis; RMK22 rack mount kit
• (W x D x H): 17.25” x 16” x 4.25 ” / 3.5” without feet
Net Weight
27 lbs , 12.3 kg
https://cdn.shopify.com/s/files/1/0763/ ... 1720883330
parasound 2125 4 small.jpg (101.19 KiB) Viewed 4065 times
parasound 2125 2 small.jpg (137.13 KiB) Viewed 4075 times
parasound 2125 1 small.jpg (110.79 KiB) Viewed 4075 times
patbarrydub
Re: FS Parasound 2125 Amplifier
Post by patbarrydub »
Hi, do the know if the feet can be removed easily and is it operational without them cheers?
woodlands
Post by woodlands »
Yes, the feet are only plastic and can be removed and it's fully operational. Best Regards Philip
woodlands
Post by woodlands »
Sold
