Edgar Audio Speakers
For Sale/Wanted
Edgar
Post by Edgar »
Hello to all fans of good sound and music lovers.
I would like to present to you speakers entirely of my design and production. The most significant feature of all my speakers, which makes them stand out from the majority of speakers on the market (regardless of cost), are the unique built-in crossovers that separate the electrical signal between the emitters. Initially, a “musical” circuit is used (filter order and approximation), which is then very carefully adjusted for specific pre-measured and selected emitters, in order to obtain the most even amplitude-frequency and especially phase-frequency characteristics. As a result, this is expressed in a completely solid, spacious, open and natural sound, especially of natural musical instruments and voices. Speakers are not picky about genres; they perfectly reproduce classics and jazz and will surprise fans of rock and especially high-quality recorded electronic and modern popular music.
Speakers based on top Dayton Audio drivers 7" midbass and 1" tweeter. Acoustic design - bass reflex. Audiophile components in crossovers, internal connections are made with specialized oxygen-free copper wire. Manufactured in Ireland. The cost of a pair is 2000 euros.
Nominal resistance - 4 Ohms.
Power (RMS) - 120 W.
Sensitivity (2 V/1 m) - 85 dB
Reproducible frequency range (+/- 3 dB) - 45 - 20000 Hz.
The lower reproduced frequency (-10 dB) - 35 Hz.
Crossover frequency - 2200 Hz.
Dimensions (hxwxd) - 410x220x280 mm.
The weight of one column is 9.0 kg.
I invite everyone to audition, it is advisable to bring your own music, CDs or music files on media, I have a computer with a sound card.
I will also be happy to bring the speakers to you to listen to them in your system and room.
Edgar
Re: Edgar Audio Speakers
Post by Edgar »
Hello to all audio lovers, at the link below you can watch and listen (recorded on a phone), some of my previous works.
https://photos.app.goo.gl/tsvPKgAkWafyNAZw8
hudo
Post by hudo »
Very interesting project, finish looks very good and professional!
Saw many speaker modifications in your photo gallery, you're doing that also?
♪♫ sound sommelier ♪♫
Edgar
Post by Edgar »
Thank you for your interest in my speakers, you know the finish is really not bad, but the most important value of my speakers is their sound. It is seriously different from what the market offers today. Yes, of course I can repeat my previous projects, but I also have new very interesting developments.
Edgar
Post by Edgar »
Also on the way is this acoustics, the finishing is not done yet, but the sound is completely adjusted and you can already listen to them. German Eton emitters are used, the material of the woofer diffuser is 7" paper without impregnation. Sensitivity 88.5 dB, resistance 8 Ohm.
IMG_20241122_124226 .jpg (114.51 KiB) Viewed 5591 times
IMG_20241122_124209 4.jpg (77.23 KiB) Viewed 5591 times
Edgar
Post by Edgar »
A few more photos
Edgar
Post by Edgar »
Friends, hello everyone.
Finished new acoustics. 2-Way, bass Seas 10“ paper with impregnation and tweeter Morel 1” silk dome, both from the top lines. The acoustic design is phase-inverted in the floor. I use unique phase-coherent crossovers of my own design, using high quality components and very precise tuning, unattainable in mass production. Dimensions 340X350X1040 mm. Finish - royal lacquer. Sensitivity - 94 dB. The speakers are perfect for tube amplifiers as well. The reproducible frequency range (-3 dB level) is 38-20000 Hz. The lower limit frequency (-10 dB level) is 29 Hz. Rated power is 120 W.
Acoustics not only with high sensitivity, but also with a flat impedance characteristic. These two qualities are very important for tube amplifiers, so it is well suited for them, including low-power and single-ended triode ones. The sound is completely open and alive, very emotional. Fundamental bass. Come and listen.
Price 3000 euros.
IMG_20250618_171742 3 3.jpg (134.11 KiB) Viewed 351 times
IMG_20250618_171729 2 2.jpg (148.11 KiB) Viewed 351 times
IMG_20250618_171709 1 1.jpg (167.82 KiB) Viewed 351 times
Edgar
Post by Edgar »
A few more photos.
IMG_20250618_171814 6 6.jpg (91.57 KiB) Viewed 351 times
IMG_20250618_171802 5 5.jpg (107.19 KiB) Viewed 351 times
IMG_20250618_171748 4 4.jpg (115.83 KiB) Viewed 351 times
Adrian
Post by Adrian »
Wow…I don’t think I’ve ever seen a speaker cabinet polished to the point where it is akin to a mirror!
Visual effects alone these are worth 3K, and that’s before we start to get into the drivers and how they sound!
Fantastic work!
Edgar
Post by Edgar »
Thank you, Adrian. I didn't do the finish myself, but it really is done very well. What's most interesting, though, is how good they sound — after that, even such a beautiful finish takes a back seat. You're welcome to come and have a listen.
