Icon Audio MCTX Moving Coil step up (broken and free)
For Sale/Wanted
Brutus1968
Post by Brutus1968 »
Hi, I have this step up with both coils interrupted so I am giving it away for free. It is useless now but a DYIer ca use its case to install new transformers.
Best
Max (spin the black circle)
Re: Icon Audio MCTX Moving Coil step up (broken and free)
I take it the transformers are potted? What a pity they can't be repaired....
Brutus1968
Fran wrote: Sun Apr 28, 2024 8:40 pm I take it the transformers are potted? What a pity they can't be repaired....
Hi Fran,
honestly I am not sure if it can be repaired. I assume it is too much of a mess to understand where the interruption is. After years of service one channel went off, so I made several tests to verify where the issue could be and my conclusion was the responsible being the step-up. Then I made my big mistake: I used a tester a final verification and I burned the other channel as well. I bought the step-up for the Denon dl-103 but I would like to change cartridge soon (with higher output V) and I will use my Manley Chinook as phono stage (no step-up).
If you need it to be posted I will have to find a box, but can prepare something in the next days.
Best
Max
Brutus1968
PM sent
Best
Brutus1968
Step up gone now.
Thanks Fran for the lovely chat.
Best
