Greetings. It's been a while.
I have some unused Duelund DCA12GA Speaker Cable that I probably won't ever use so I'm offering it for sale.
Bit of background: https://positive-feedback.com/audio-dis ... es-part-1/
Some people are loving it for speaker wires and interconnects.
I have 2 lengths - 1 at 12 metres continuous and 1 at 19 metres continuous.These are single runs so, for example, the 12 metre length cut into 4 would give you a set of 3 metre speaker cables.
This retails at €21.90 here:
https://www.playstereo.com/en/cavi-di-p ... _conductor
https://www.hificollective.co.uk/wire/d ... lated.html
I'm asking for €15.00 per lin. metre
Thanks for looking 🎶
SOLD - Speaker or hook up wire.
Re: Speaker or hook up wire.
pm sent
Hi
No PM received. I’ll keep an eye out. Thanks.
Hi
Is the 19m length still available?
19 metre is gone. 12 metre length still available.
