Best hifi gadget you own?
Well, the title says it all. What is the best geegaw, faldal, widget, gadget, apparatus, tool, contrivance, device or gizmo that you have in your hifi room?
HiFiFan
Re: Best hifi gadget you own?
Post by HiFiFan »
Probably my FIIO Compact Fully Balanced USB DAC/AMP (dongle) that lets me use my balanced IEMs with my phone.
My WiFi router. The fact that I now have a world of recorded music throughout history at my immediate disposal in at least CD quality boggles my mind.
hudo
Post by hudo »
Laser distance meter probably:)
♪♫ sound sommelier ♪♫
I'm torn between a few gadgets....
Something I only use now and again is a Feickert alignment gauge, but very useful thing to have
If you are testing equipment, a sound level app on the phone is very handy indeed to make sure you are not fooling yourself with a louder/quieter playback
Hard drive with lots of choice is another one - bluetooth is another
Adrian
Post by Adrian »
Probably turntable set up / alignment tools, used very infrequently but when required are an absolute must. Spirit level is handy too.
Most used gadget would be remote control for the amp.
Hard drive. What a space saver. I can now fill the room up with bass traps and other paraphernalia instead of Cd's and Lps!
Brutus1968
Post by Brutus1968 »
Definitely the Dspeaker antinode 2.0. When in Italy my hifi room had a terrible resonant peak around 50Hz (where most of the bookshelf speakers reflex tube emits). After trying a number of "passive" solutions and changing several speakers I finally decided to buy it, and it brilliantly solved all my problems. To my surprise the effect of removing unwanted bass boosts come together with a lot of details in the mid-high region that now could flourish. And with such a tool I could use any speaker in the room now, saving a correction curve for each one (up to 4).
Where I am living now I am not using it as digital corrector, but as DAC for both my digital files on the PC and the optical signal from a CD player. A very flexible item indeed.
Best
Max
Max (spin the black circle)
My favourite essential gadgets are definitely my Vinyl Passion Dust Buster stylus cleaner and Deram Record Cleaning Brush. The DB is used before and at the end of my session. The Deram brush is not used in the recommended fashion for cleaning records. I use it per side of listening on the stylus! It contains just a single row of very fine carbon fibres and it’s very effective indeed but only if it is used regularly.
peelaaa
Post by peelaaa »
Is it a gadget or not?, who knows but I use a magic eraser for removing dirt/dust from the stylus. Reading Cybot post above, the dust buster could be an alternative I may try.
I also use a disco anti-stat record cleaner. Great results from this, using the supplied liquid.
