Sold on Ebay my god the fees are mad.
Cyrus DAB8 FM/Dab Tuner.Black. Remote control. Boxed with manual in pristine condition.Never used hence decision to Sell.
Looking in region of €375. This item is as new.
Plenty of detail on this below.
The DAB 8.0 is a band III DAB tuner with FM & RDS. Not only is it a top quality DAB radio, but is extremely convenient to use with state-of-the-art features. It has an Electronic Programme Guide (EPG), letting you select and plan your DAB listening up to one week in advance, and a record function so you can pause and rewind live transmissions at the touch of a button.
Everyone has become used to PVR’s and VHS recorders for TV and now, at long last, Cyrus can offer the same time-shifting ability for radio. Cyrus has opened the door to a wide range of radio entertainment you miss while out of the house or busy doing something else. Whether you want to listen to your favourite radio station or record a programme while you are out, the Cyrus DAB radio allows you to time-shift radio to suit your lifestyle. You can touch the “PAUSE” button and answer the phone without missing a single second, or even record a show to the SD card and listen to it when you have time, either on your Cyrus system or your portable MP3 player. A 1GB SD-Card provides over 8 hours of the highest quality recording, or 35 hours of the lowest bit rate recording.
MC-BUS is incorporated for intelligent integration into existing Cyrus systems.
What is DAB Radio? What it is not, is satellite radio or internet radio. What it is, is a new way of broadcasting - it’s like conventional analogue radio, but better. DAB radio listeners in the UK can receive between 30 and 50 stations depending on area, which in most cases, is over double conventional analogue radio. Content of DAB radio is much more varied than analogue, with over 100 different brands of music that are currently available and unique to DAB.
What can DAB offer? Not only will DAB give you more choice, it can also provide improved sound quality. The technology behind DAB tuners enables it to lock onto the strongest signal and filter out all the unwanted information, like hiss and crackle, and present only the listening content.
No more frequencies to remember, as tuners are tuned by name. Broadcasters are also transmitting more information using Dynamic Label Segments (DLS), giving you, the listener, up to date information. Some stations are already transmitting the latest news, travel and ‘what’s on now and next’ direct to the display of your tuner.
What does the DAB 8.0 give you? The Cyrus DAB 8.0 features band III DAB decoding, Electronic Programme Guide (EPG), letting you select and plan your listening up to one week in advance. Pause and rewind live transmissions at the touch of a button, a timer, or instantaneous recording to an SD card, also allowing for playback of MP3 files previously stored on a SD card from a PC.
Cyrus DAB8 Tuner For Sale (SOLD)
