passive pre
paulb
passive pre
Post by paulb »
just a quick question....am i right in thinking a passive pre should be mute than increasingly louder?got one and twisting the volume is mute than loud then half way- low and gets increasingly louder(in a normal way)....did i get a dud?hope it makes sense..it sounds good and can work around by pausing but im worried ill damage my power amps.
Re: passive pre
Eh, that doesn't sound right - it should work exactly the same way as any other preamp, say off (7oclock) is mute, then smoothly progressively louder until the end of travel.
Definitely should not go up and down - sounds like its wired wrongly inside to me.
paulb
Re: passive pre
Post by paulb »
kind of had the same feeling...at least it was cheap enough and now i know i want a passive pre... thanks
Re: passive pre
Sounds very like they soldered the wires to the wrong pins on the pot.....
Matt
Re: passive pre
Post by Matt »
Hi Paul
Ive this single input passive volume control if its any use to you? It has xlr ins and outs.
http://www.tcelectronic.com/levelpilotdetails.asp
Matt
Arcam Cd33, Vdh The Integration, ATC CA2, Gotham GAC-2v1 XLR, ATC scm50asl
paulb
Re: passive pre
Post by paulb »
looks great but i would need rcas
Matt
Re: passive pre
Post by Matt »
No problem Paul.
paulb
Re: passive pre
Post by paulb »
if anybody has a passive pre for sale or knows a good deal please let me know....
