Sorted. Wanted a 100 Volt transformer
For Sale/Wanted
willsandbills
Post by willsandbills »
Sorted Just wondering if anyone has one , its to operate a Japanese piece of equipment. Most any size will work as its for a cd player
Re: Wanted a 100 Volt transformer
I've only 110V (ie US) ones.
Do you just want to see if its working?
willsandbills
Thanks for that, i have 110 v ones but they actually produce about 118 v. I also have a variac that I can use temporarily .
Appreciate the reply
willie
Ah you're well sorted with the variac so.
willsandbills
Not sorted as the Variac is a monster, so need something a bit smaller
