Thorens TD124 suppression capacitor wanted
Brutus1968
Post by Brutus1968 »
Hi there,
I am looking for the capacitor in the subject. It should be Class X2, 10nF, 275Volt AC. There is one on hanzehifi.nl shop for 4 euros, but the shipping would cost me 25 euros.
Do you have any shop in Dublin to suggest me where I could find it?
Thank you
Max (spin the black circle)
Re: Thorens TD124 suppression capacitor wanted
I thought I might have had one but when I went looking I couldn't find one.
Farnell or radionics will have them....
Brutus1968
Thanks Fran,
Looking on google I thought Radionics could be a good one to try. Thanks for confirming that.
Radionics have a set low delivery charge - I think its about 10e or so. It might be free to pick it up from their warehouse in Rialto. Farnell do a handling charge of 9e but if you buy over either 30e or 50e worth of materials its free shipping.
Also meant to say - those caps would be very common in things like switch mode power supplies etc - if you have some scrap computer power supplies etc you might be able to recycle one.
Brutus1968
Hi Fran, thank you very much for all the info and suggestions.
Best
Brutus1968
In the end I found the capacitor at Farnell. Substitution done, and now the TD124 is running (and stopping) again.
Thanks for your help
Great result! It always amazes me how such a small part can cause such s big problem... it shouldn't but it does!
Brutus1968
Ivor wrote: Sun Oct 24, 2021 7:30 pm Great result! It always amazes me how such a small part can cause such s big problem... it shouldn't but it does!
Swiss engineering skills...
