Plinius Anniversary Edition Integrated Amplifier
For Sale/Wanted
seven3
Post by seven3 »
Wonderful high end integrated amplifier rated at 2x200W into 8 Ohms.Powerful and fast, dynamic, warm and smooth sound.HT Bypass and excellent phono stage.Technically identical to the Plinius Hautonga. Cosmetically, the only difference is in the shade of the silver finish.
Power:
200w RMS per channel into 8 ohms
280w RMS per channel into 4 ohms
Both channels driven from 20Hz to 20kHz at less than 0.2% total harmonic distortion
Frequency response:
20Hz to 20kHz +/- 0.2dB
-3dB at 5kHz and -3dB at 70kHz
Distortion:
Typically <0.05% THD at rated power
0.2% THD and IM worst case prior to clipping
Gain:
Line inputs to speaker out: 40dB
Phono input To Pre-Out: 66dB on high gain,60dB on low gain
€2,900 ono
https://www.adverts.ie/home-audio/plini ... r/23126159
