Hi guys, I want to ask if anyone has some experience with Wooden Bull Leather & Cork turntable mats?
Cheers.
Turntable Mats
Re: Turntable Mats
Not with those exact mats but... bear in mind if you add a mat you will be changing the VTA as the cart will sit higher. If you replace an existing mat try to get one the same thickness so the swap is straightforward.
Re: Turntable Mats
You just can't beat a wise old head (metaphorically speaking) for advice!
Re: Turntable Mats
I've never used those, but I have had excellent results from an achromat (which aren't cheap but not ridiculous either) but as Ivor says, you have to make sure you keep the VTA the same as that definitely will change the sound.
good results can be obtained though for sure.
Re: Turntable Mats
I'm interested to hear we have a local user of the Achromat because I'm seeing a lot online about it. I slightly hate the felt mat on the Rega because quite a lot of the time it sticks to the record as you lift it, which suggests a lot of static on the go. I'll watch this thread with interest.
Nerdcave: ...is no more!
Re: Turntable Mats
I got one of those mats to replace the mat on my Technics SL 1200G.
It was a little warmer sounding than the original one.
I certainly prefer it to the rubber one.
Re: Turntable Mats
Thanks for the response and advice.
I have about 6-7 different mats from various materials, but want to try Leather ones.
