Wilson Benesch - Square Three - Floorstanding Speakers
For Sale/Wanted
Fitzgeme
Post by Fitzgeme »
Over on adverts https://www.adverts.ie/home-audio/wilso ... s/17881346
Best to contact me on adverts if your interested, I check there more than here, thanks.
Pristine Condition with Box's and packing. Never moved since unpacked. Non smoking household. Serious high end speakers from a serious high end manufacturer.
BURR WALNUT GLOSS finish
Purchased in 2017 from Listening Suite RRP €5700 - https://www.thelisteningsuite.ie/wilson ... are-three/
Tech Specs here - http://wilson-benesch.com/square-three- ... udspeaker/
A 2.5-way hand-crafted, floor standing loudspeaker. The Square Three is a serious high-end loudspeaker, with dedicated, highly optimised Tactic Drive Technology.
The presentation is fast, dynamic and tactile, delivered with all the poise and composure common within the Wilson Benesch family sound. Taking over where the Square Two left off, the Square Three adds a second Tactic Drive Unit to divide bass and midrange over two dedicated Tactic Drive Units. The result is a rich, detailed and beautifully composed presentation. Every nuance of the music delicate vocal or string — and every detail and micro-dynamic structure of a double bass or drum strike is delivered in a lifelike soundstage.
Unique, innovative design concepts have been distilled in the Square Three, combined they create a highly optimised, floor standing loudspeaker which shares much of its DNA with the Vector loudspeaker in the companies reference line, the Geometry Series.
With two Tactic Drive Units and a bespoke, Wilson Benesch spec, Scanspeak Tweeter the Square Three delivers a frequency range from 35Hz to 24kHz. A minimal crossover design ensures that the bespoke drive technology is free to operate optimally, with a pure signal path between the drivers and the amplifier.
Finished with a high gloss or matt veneer expertly handcrafted by Bentley Motors trained craftsmen and the low profile laser cut steel grill create the finishing touches to a remarkable, British built loudspeaker.
SPECIFICATIONS
Description: 2.5-Way, Ported Enclosure with Mid & Bass Assisted Bass Radiators. Internally braced & damped with Carbon Fibre Ribs & Critical Mass Damping Pads.
Drive Units: 1 x 170mm (7in) Wilson Benesch Bass Unit, 1 x 170mm (7in) Wilson Benesch Mid Range Unit, 1 x 25mm (1in) Soft Dome Hand painted Silk, Ultra Linear Wilson Benesch Specific Tweeter.
Low Freq. Loading: Double chamber, Tuned Bass Ports at the base of the Cabinet.
Freq. Response: 35Hz to 24Khz
Sensitivity: 87dB spl (2.83V/1m)
Impedance: 6 Ohms Nom / 4 Ohms Min.
Crossover: First order bass roll-off. Second order tweeter crossover. Selected polypropylene capacitors and air cored inductors are used throughout.
Crossover Freq: 500Hz / 5kHz
Internal Wiring: Multi-stranded, silver plated copper, PTFE jacketed cable harnesses. Soldered connections throughout. Short path PCB design
Input Connections: Bi-wireable, in-house machined rhodium plated copper alloy terminals. Links supplied for single or bi-wire application.
Height:975mm (38")
Width: 200mm (8")
Depth: 255mm (10")
Internal Volume: 32L
Weight: 32kg / 70.5 lbs
