you know its hot when....
The quads started sizzling today - had a look at the neon bulb - flashing really quickly, normal rate is 1 in 10seconds. Shows how high the humidity is!
Re: you know its hot when....
Quads are sizzling here also! Well they are running fine is there something up with yours Fran? Have the Jadis back in and all is sounding grand here. Think I will ignore the blinking light just in case!
tony wrote: Sat Jun 02, 2018 9:17 pm Think I will ignore the blinking light just in case!
Spot the Citroen driver!
Ivor wrote: Sat Jun 02, 2018 10:30 pm
:-) brought a smile.
tony wrote: Sat Jun 02, 2018 11:03 pm
As intended :)
I didn't know Spot had a Citroen.
Will Declan be getting his licence anytime soon?
Derek wrote: Sun Jun 03, 2018 11:01 am I didn't know Spot had a Citroen.
Howling as I hang from the chandeliers here
tony wrote: Sat Jun 02, 2018 9:17 pm Quads are sizzling here also! Well they are running fine is there something up with yours Fran? Have the Jadis back in and all is sounding grand here. Think I will ignore the blinking light just in case!
Nah, they're good. When the humidity is really high, the high voltage "leaks" across in the moist air and the panels have to be recharged more quickly - which is what the neon bulb shows. Its fairly rare in Ireland to get humidity high enough to do this.
