Best way to organise multi-disk works : Playlists ?
Post by james »
Hello,
I am wonderring how to deal with ripping CD box sets which contain works that span multiple CD's. [Example : I have a set of Mahler symphonies -- the live Bernstein rcordings -- and some of the CD's have parts of more then one symphony and some symphonies use more than one CD].
I am using a Squeezbox [and SqueezServer].
I have the CD's ripped to CD1, CD2, CD3 etc ...
I could make new folders/directories called SYM1, SYM2, etc and move the appropriate tracks for each symphony into the appropriate folder/directory.
Is that the best way to do things or should I create playlists ? I have never actually used a playlist and I am not too sure how they work ?.
James
Re: Best way to organise multi-disk works : Playlists ?
Post by james »
http://www.amazon.co.uk/gp/product/B003 ... d_i=468294
The above set shows the problem .. there are 11 disks and the symphonies are split across the CD's to save space. I really want things organised by symphony rather than as discs ....
