Low noise 24V 4A regulator
tims
Post by tims »
Hi
I've been looking at this Belleson regulator to give me 24V @ 4A here: https://www.belleson.com/store/SPHP-High-Power. It's capable of up to 100V @ 10A and low noise at <5µV/Vout but probably overkill for what I need plus my funds probably won't stretch that far.
I wouldn't mind DIY'ing something to cut costs but there don't appear to be many low/ultra low noise regulators at this voltage. The closest I've found is a LT3086 here:http://cds.linear.com/docs/en/datasheet/3086fb.pdf at up to 40V @ 2.1A that can be paralleled to give 4.2A but these are tiny DFN/TSSOP packages that require the ground slug(?) of the regulators to be soldered onto the PCB (for heat-sinking) and beyond my abilities I think.
Anyone know if of anything else I can buy (ebay?) or would the Belleson reg above be my best bet?
Re: Low noise 24V 4A regulator
lm338t is a beefed up lm317
something like this
http://www.ebay.com/itm/5-Amps-Voltage- ... 0689004069
just need a suitable transformer
24v x 4 amps is 96 w is quite a lot of power are u sure its needed?
frd1996
Post by frd1996 »
If LM338t is under consideration, then LT1084 or LT1083 is much better choice.
randytsuch
Post by randytsuch »
BTW, looking at the pic of the belleson, hard to believe it can put out 10A.
randytsuch wrote: Thu Sep 14, 2017 3:57 pm BTW, looking at the pic of the belleson, hard to believe it can put out 10A.
its only controlling that mosfet to do the heavy lifting id guess
randytsuch
nige2000 wrote: Thu Sep 14, 2017 4:02 pm
(slaps his head for missing the obvious lol)
Of course. But they don't show the BIG heatsink you'll need on the mosfet.
tims
Post by tims »
Thanks for all your replies!
