pre or power
paulb
pre or power
Post by paulb »
witch do you turn on first?the pre amp or the power amp?know silly but cant think of it...
Re: pre or power
When switching on it is the pre first....then the power. It is the reverse when switching off.
HiFiFan
Re: pre or power
Post by HiFiFan »
Some equipment allows for (usually a 12v) trigger that can be used to automatically power on and off the power amp.
