FS The Wazoo Intergrated Amp
For Sale/Wanted
woodlands
Post by woodlands »
Here for sale is the Bow Technology - The Wazoo - Integrated Amplifier.
Complete and in great condition (but no remote).
Really sounds like a valve amp !
Reviews and further info ....
http://www.tnt-audio.com/ampli/wazoo_e.html
http://www.audioreview.com/cat/amplific ... 83crx.aspx
https://www.stereophile.com/integrateda ... index.html
https://www.stereophile.com/content/bow ... ier-page-2
Euro 1000
Specs;
Solid-state integrated amplifier
Inputs: 5 pairs line-level, 1 pair single-ended and balanced.
Outputs: 1 pair preamp/monitor.
Binding posts: 4 multiway WBTs.
Continuous power: 50Wpc into 8 ohms (17dBW), 90Wpc into 4 ohms (16.5dBW).
Frequency response: 2Hz--200kHz (--3dB). S/N ratio: 110dB, A-weighted, ref. full power. Channel balance within 0.3dB.
Input sensitivity: 500mV. Input impedance: 1.2k ohms. THD: <0.5%.
Power consumption: 70W idle, 500W max.
Dimensions: 17.1" (434mm) W by 5.5" (140mm) H by 16" (407mm) D. Weight: 44 lbs (20kg).
the wazoo 1 small.jpg (79.46 KiB) Viewed 943 times
the wazoo 2 small.jpg (69.92 KiB) Viewed 943 times
