This Cambridge Network Player is in excellent condition. (Includes Power Cable, Remote Control and WiFi Dongle)
Detailed Specifications :-
DAC Dual Wolfson WM8740 24-bit DACs
Digital filter 2nd Generation ATF2 up-sampling to 24-bit/384kHz. Linear Phase, Minimum phase or Steep modes.
Analogue filter 2-Pole Dual Differential Bessel Double Virtual Earth Balanced
Digital Input S/PDIF 75 ohms or TOSLink optical
USB Audio Input USB Type B conforming to Audio profile 1.0 or USB Audio profile 2.0 (user 1.0 or USB Audio profile 2.0 (user selectable)
Analogue audio outputs Balanced XLR and unbalanced RCA analogue audio outputs
UPnP 16-24 bit, 32-96kHz
Local USB media 16-24 bit,
32-96kHz USB Audio1.0 16-24 bit,
32-96kHz USB Audio 2.0
16-24 bit, 32-192kHz
Toslink 16-24 bit, 32-96kHz
S/PDIF 16-24 bit, 32-192kHz
Audio formats ALAC, WAV, FLAC, AIFF, WMA, MP3, AAC, HE AAC, AAC+, OGG
Standby power consumption <0.5W
Dimensions (H x W x D) 85 x 430 x 305mm (3.4 x 16.9 x 12.2”) Weight 4 kg (8.8lbs)
Euro 375 reduced from 450
Sold - Cambridge Stream Magic 6
- stream 3 small.jpg (29.12 KiB) Viewed 2346 times
- stream 2 small.jpg (26.9 KiB) Viewed 2346 times
- stream 1 small.jpg (30.15 KiB) Viewed 2346 times
Re: FS Cambridge Stream Magic 6
Hi, is it possible to 'Airplay' to this from an iPad or iPhone? Thank you.
Hi,
I am afraid that Apple Airplay is not supported ....however,,,
Optional BT100 Bluetooth adaptor (USB) (not supplied) When connected to Stream Magic 6 this adaptor allows the Stream Magic 6 to receive BluetoothAudio (known as Bluetooth Advanced Audio Distribution Profile or A2DP). The BT100 supports Bluetooth A2DP using either the original SBC encoded form or the latest higher quality apt-X encoded form.which can be any type that your phone/ laptop or other playing device supports.
Your playing device plays your files then re-encodes the playback before streaming it to the BT100 in one of these two formats.
I have used an off the shelf USB bluetooth adapter which worked exactly as the Cambridge BT100 device as a lower cost.
hope this helps.
Best regards Philip
hope this helps.
Best regards Philip
Is still for sale ??
Yes , is still available for offer or listen.
PM sent Philip. Thank you.
No message received, will you try again. Regards
