Canor TP10 Valve Hybrid Headphone Amp
For Sale/Wanted
http://www.canor-audio.com/?page_id=77
Fantastic amp in fantastic condition.
Selling just because I don't use it.
For sale at €320.00
RRP St £850.00 - http://www.musicarch.co.uk/canor-tp10-h ... mplifier/
• The CANOR TP10 is a headphone tube amplifier of hybrid structure, and it is a direct successor to the highly popular and successful SH-1 model.
• The new model has a completely redesigned and improved power supply.
• The amplifier uses superior operational amplifiers (Burr-Brown), and top-echelon polypropylene capacitors.
• Unlike SH-1, the 12AX7 tube is replaced by 12AT7 input tube. ALPS potentiometer is connected to the axis via flexible coupling and a bearing, in order to provide a fine, smooth motion of the knob.
• The front panel is made of 10 mm thick aluminium.
• Input connectors are gold-plated RCA phono plugs. By-pass output is equipped with same connectors.
• The tube amplifier is powered from an external adaptor
• External adaptor significantly increases signal-to-noise ratio which we consider together with musical expression of the amplifier as one of the most important qualities of the amplifier.
• The TP10 can drive dynamic headphones from 30 ohms to 300ohms.
• All tubes are being burned-in and measured on our specially developed BT-2 and TTM-2 measuring devices.
InTerZaiNeR
Re: Canor TP10 Valve Hybrid Headphone Amp
Post by InTerZaiNeR »
Hello!
I'm french, sorry for my bad english.
I'm (very ^^) interested for your amp.
You think it would be possible to send it to French?
I will pay the shipping costs.
cordially
Withdrawn.
bonenut
Post by bonenut »
this is hardly still available?...cheers.john.
