Hi Guys,
I'm looking at getting a linear PSU for my Chord Qute EX DAC, it seems to be 12v 1A.
Do you think it could accept 12v 2A without any risk?
The ones on web specifically for this DAC are very expensive and I would rather have a DYI one or a cheaper version :)
Chord Qute EX DAC - Linear PSU
Re: Chord Qute EX DAC - Linear PSU
yea thats fine.
usually a minimum requirement thing
Perfect ! Thanks Nigel
So the below one could work :
http://www.ebay.ie/itm/142032009721
Sent from my Redmi 3S using Tapatalk
yea should be ok
ships from china
make sure is 220v
ships from china
make sure is 220v
