Hi,
I'm selling my vintage Trio (that's the high end brand of Kenwood) W-41.
It's a vintage valve amp from the mid sixties.
It has been serviced, by the previous owner, last year (by a british guy - Retro Amps, in newton abbot. he replaced faulty components, but didn't change all the capacitors).
https://www.facebook.com/Retroamps/phot ... 0482537736
It produces 18W for 8 or 16 ohms speakers (4 ohms FORBIDDEN ! And never turn on a valve amp without speakers connected to it !).
No "hum", no problems. Though, keep in mind, even if its well built like, it will need a service every few years (5 +/-).
It plays very well, and you'll get that charming vintage valve sound.
I got a owner manuel (well a scan).
It's a vintage classic, even the guys from 45rpm, who are really mean, have them in their listing.
http://select45rpm.com/pages/hifi/vinta ... s.html#136
I'm selling it, because i got my hands on a Rogers Cadet 2, that i got fully recapped and restored to its former glory, by London Sound, the specialist of the Rogers Brand, for a fortune...
well, compared to the price i'm selling this sweet little amp.
A mere 550 euros.
Of course you're welcomed for a listening cession, you can bring your speakers to test the marriage, your DAC, etc.
(Unless it's for using it in a bedroom, sensibility of the speakers should be at least 90 db).
Cheers,
François.
PS: tech info :
http://www.radiomuseum.org/r/trio_kenwo ... guage_id=2
2 x 18 watts (without strain)
Inputs: phono, AUX, tuners, tape
Frequency response: 20Hz ~ 20kHz (output of 500 mW, 0.5dB)
50Hz Tone Control: +12 dB ~-10dB
10 kHz: +12 dB ~-9dB
Speaker systems 50Hz: +13 dB, 10kHz: +4 dB
Tape Monitor
Vacuum tubes (9) 12A X 7: 5 pieces
6BQ5: 4 pieces
Silicon diodes: 2
Supply voltage: AC110-117V/220-230V, 50Hz/60Hz
Power consumption: 130 watts
Dimensions: 313 x 126 x 252 mm
Produced in: 1964 years
Trio W-41, classic Vintage Valve amp, 18 W
- IMG_1970.JPG (109.78 KiB) Viewed 1472 times
- IMG_1968.JPG (102.55 KiB) Viewed 1472 times
- IMG_1966.JPG (64.54 KiB) Viewed 1472 times
