jriver
bonenut
jriver
Post by bonenut »
i just downloaded the free trial of jriver and am impressed.i used itunes for as long as i can remember but recently received some highres 192 khz audio and other types and re ripped all my music to alac.but when played in itunes to my dac it never changed the dac input(the dac always displayed 192khz,as its set like that)but when i play in jriver ever time i change from 192 to 96 to 44 khz the dac reads it and changes the front panel to match the song on jriver.is itunes doing it own thing and resampling things..i am new to all this type of stuff.
any help is appreciated.cheers.
randytsuch
Re: jriver
Post by randytsuch »
Most people here don't use jriver, hence the lack of responses.
I have a SD card player, so no PC used during playback. The SDTrans384.
I used to use MQN, and liked it. But it doesn't do hi rez, unless its has been added since I stopped using it. He was working on hi rez.
wtfplay is also popular now. Its relatively new, and I haven't tried it.
There are threads on both of these here. lekt player also has a long thread.
meep
Re: jriver
Post by meep »
Not clear on exactly the question but it sounds like jriver is behaving as expected, outputting the content at the native sampling rate.
You can set it to upsample but would you want to?
I used it for a while and found it very powerful and flexible. Stopped using as it just didn't fit with the rest of my setup.
