power amp wanted.
For Sale/Wanted
bonenut
power amp wanted.
Post by bonenut »
above wanted.in and around the five hundred mark.cheers.
halvis
Re: power amp wanted.
Post by halvis »
Not sure what you had in mind but I have one of these I might let go of - MC2 Audio MC650
It will literally drive anything as you would expect from the specs. Not the prettiest amp for your hifi rack, but in good condition and was serviced about 2 years ago.
I would be looking for €600.
PM me if interested.
bonenut
Post by bonenut »
thanks for the offer but yes,not what i had in mind.cheers.
meep
Post by meep »
Might be tempted to let my Emotiva XPA-2 go at around that price if you're interested?
Was using it to drive a pair of B&W 803Ns but now a bit surplus to requirements. (using an XPA-3 & a new a/v processor for additional channels).
https://www.audioholics.com/amplifier-r ... xpa-2-gen2
XPA-2 Features
Refined and optimized dual differential Class A/B topology.
Stereo Mode and Mono-Block Mode for exceptional flexibility.
New precision engineered chassis w/ solid 15mm milled aluminum faceplate Automatic 120/230 AC voltage detection and switching.
High-speed Multi segment bar graph output level meters with clip detect.
Metering and status LED on/off switches.
Fully protected from all fault conditions.
Soft start circuitry.
Advanced microprocessor operating system.
External trigger turn on and trigger output.
Soft touch power switch.
Input: balanced (XLR) and unbalanced (RCA), switchable.
High current match pair on semi output devices.
Heavy duty Audiophile quality gold plated 5 way binding posts.
XPA-2 SPECIFICATIONS
Number of channels: 2 (stereo mode), 1 (monoblock mode)
Topology: fully discrete, highly optimized dual differential, high current, short signal path Class A/B with premium components throughout
Power output (all channels driven):
1000 watts RMS @ 8 ohm (Mono-Block mode)
500 watts RMS per channel @ 4 ohm (0.12% THD)
300 watts RMS per channel @ 8 ohm (0.07% THD)
Rated power bandwidth: 20 Hz to 20 kHz +/- 0.07dB
Broadband frequency response: : 5Hz to 100kHz, +0 -3dB
Amplifier gain: 29 dB
Signal to Noise Ratio:
1 watt: > 97 dB
Full power: > 121 dB
Input impedance:
unbalanced: 23.5kohms
balanced: 33 kohms
Power supply: 1,200VA toroidal transformer with 45,000uF low ESR storage capacitance
Size:
unboxed: 17” wide x 7 3/4” high x 19” deep
boxed: 23 1/2" wide x 12" high x 24 3/4" deep
Weight: 72.6 lbs (83.5 lbs boxed)
bonenut
Post by bonenut »
that looks to be a fantastic amp and was getting excited until i saw the size,i have a rack for my computer and hi fi and no matter what way i cut it it wont fit.bummer.cheers anyway.
meep
Post by meep »
No worries
It's a beast alright. Good luck with your search.
Terry
Post by Terry »
bonenut wrote:not what i had in mind.cheers.
To help you and the rest... what do you have in mind? What speakers are you using?
bonenut
Post by bonenut »
i have a primare i20(70 watts) and also a couple of dacs(marantz hd dac1 and audiolab mdac)that can power a power amp straight.at the moment i have computer to marantz to primare to audio smile kensai speakers which are quite inefficient(93db).so i was looking for a power amp basically to play around with powered straight from the dacs or use the primare s a pre amp.
so hopefully a power amp over 70 watts,or see what people have.cheers.
Komornick
Post by Komornick »
Will you consider rack mounted Bryston power amp 2x120W Ohm
Its in mint condition. If yes please let me know.
bonenut
Post by bonenut »
lovely amp and great specs but i would imagine it exceeds my budget by a long shot.how much were you looking for it.
