microrendu
microrendu
Just wondering whether we can all retire from burning holes in the carpet. Has anyone heard one, or better still compared one to a fully tricked out audio PC?
Re: microrendu
Have you seen our sd card player interpretations?Crom wrote:Just wondering whether we can all retire from burning holes in the carpet. Has anyone heard one, or better still compared one to a fully tricked out audio PC?
Much less problems to fix :)
Re: microrendu
FWIW, I have one on order.... I'll post here when I've had a chance to assess it.
- Sloop John B
Re: microrendu
rab wrote:FWIW, I have one on order.... I'll post here when I've had a chance to assess it.
What equipment are you going to use it with and which of the 5 outputs are you going to use?
SJB
Re: microrendu
Will start with squeezelite and mpd modes, but plan to explore HQP /NAA.Sloop John B wrote:rab wrote:FWIW, I have one on order.... I'll post here when I've had a chance to assess it.
I will be powering it with a js-2 supply modified with Hashimoto iron and new ps caps.
This into 4 possible dacs (including a Soekris being built), then into modified line magnetic 518IA amp into diy 4 way horn based speakers...
Re: microrendu
What will you be using as reference source for comparisonrab wrote:Will start with squeezelite and mpd modes, but plan to explore HQP /NAA.Sloop John B wrote:rab wrote:FWIW, I have one on order.... I'll post here when I've had a chance to assess it.
Re: microrendu
At the moment I am using an Intel atom motherboard with the SoTM usb pcie card and the separate click upgrade board, both powered with the JS-2, a jcat or curious sub cable to an Intona isolator, and the curious regen link to my dacs.
Re: microrendu
Oh, and software is Linux snakeoil, also I have wtfplayer and Windows server 2012 with jplay, jriver. Also a second pc to do the jplay two pc thing.
Re: microrendu
Thanks! Looking forward to your comments......
- Sloop John B
Re: microrendu
Well were you in the June batch and what do you think of it?
SJB
