WANTED - turntable & phono stage
For Sale/Wanted
mjam
Post by mjam »
WANTED Turntable and phono stage 200 budget ???
Does anyone have anything decent ?
Realise its not a lot of money but just want to test the water with vinyl.
Based in Dublin
Adrian
Re: WANTED - turntable & phono stage
Post by Adrian »
A budget of 200 is a bit on the tight side for a TT, Tonearm, Cartridge and phonostage, but it is sort of doable second hand. Depending on what comes along you may require to go up a bit to 250 or so. I'm afraid I don't have anything myself at the moment.
On the plus side phonostages can be picked up new relatively cheaply, have a look at hifihut.ie .... some good pro-ject phono stages over there for not much money.
Best of luck with the hunt!
mjam
Post by mjam »
Thanks Adrian for the reply . I realise 200e is tight , I am a little flexible.
Hopefully somebody may have something they are not using and could be put to good use.
Adrian
Post by Adrian »
Hifi Hut have all in one package... TT, Tonearm, Cart, inbuilt phono stage with DAC for computer audio as well..
Reduced from 285 to 249...
http://www.hifihut.ie/turntables-irelan ... white.html
May not be the ultimate in vinyl playback... but it is a start, brand new as well.
mjam
Post by mjam »
Ill see if anything turns up from the forum first -
I have see that and also they have the same one without phono @ 199e and I was thinking to get a seperate phono stage , would be better going forward I think.
I'm still hoping something may turn up through here
Thanks Adrian
Tweedle12
Post by Tweedle12 »
Hi there,
I do not have a spare phono stage, but do have a great Rega Planar 2 with RB250 tonearm and new Audio Technica AT95 cartridge that would be well within budget.
Best wishes,
TD
mjam
Post by mjam »
pm sent Tweedle 12 - not sure if its gone . my mobile is 0851070198.
Are you in Dublin ?
mjam
Post by mjam »
Still looking guys - Relatively small budget
if you have a decent Turntable you are looking to move on just let me know please on 0851070198
JFK
Post by JFK »
Still looking ? Have a Rega planar 3
Sent from my iPad using Tapatalk
