I am looking for someone to repair a Woo WA5. Some small capacitors are blown. After I replaced them they started to go again.
Is there anybody in Dublin area who can help me out?
Paul
Tube amp repair
Re: Tube amp repair
Sounds like it needs some problem solving so an engineer with a fair bit of experience of valve technology would be important & the circuit schema would help. If you're on the Northside of Dublin, a pro-audio engineer called John Kane might be worth ringing.
Re: Tube amp repair
Thanks,
Will try John Kane
Will try John Kane
