For sale.
Arcam AVR 200 (Home Cinema receiver). Very good condition. Remote. Manual. No orig. box. 200 euro.
Pioneer dv737. Cost a fortune 8 years ago. 50 euro. Just for laugh
http://www.audioreview.com/mfr/pioneer/ ... 87crx.aspx
Wharfedale Diamond 8.1 and 8 centre. O.k. condition. Black.Manuals. Boxes. 50 euro for 3 speakers. http://www.audioreview.com/cat/speakers ... 90crx.aspx
Mirage pb 12. Subwoofer. Black. US voltage. Transformer incl. in sale. 70 euro.
Linn Keilidh. Good condition. Original double boxes. Manual. Rosewood. With q-stone stands and Linn k 400 speaker cables. 380 euro.
http://www.audioreview.com/mfr/linn/cen ... 43crx.aspx
Or, everything above for 600 euro. + digital cable(DVD-receiver),phono cable for sub and speaker cable to hook up Wharfedale to receiver as surround. So you could have a decent Home cinema at very modest price.
Clear out
Re: Clear out
Info on the Mirage pb 12. Subwoofer, Picture?
I can't get it on the web
Re: Clear out
Hi Derek,
Specs from manual:
Type: Discrete MOSFET
Class A/B
Power output: 150 Watts
600 Peak
Woofer: 12" long throw
Frequency Response: 25-100 Hz +0/-3dB
Dimensions: 15 5/8*17*15 (in)
Weight: 45 lbs.
Can't attach photos. I'm useless with computers. It says that size of the file is too big. I guess I can e-mail pictures directly to you.
Specs from manual:
Class A/B
600 Peak
Weight: 45 lbs.
Re: Clear out
Yes, or if you need help send on the photos to me and ill stick them up for you.
Re: Clear out
http://bluefive.pair.com/pixresizer.htm
Pix Resizer is a great tool for making images smaller and it's free.
Re: Clear out
That's the one.
Ivor, Thanks for resizer.
- (212.03 KiB) Downloaded 534 times
- (197.6 KiB) Downloaded 534 times
- IMG_0490 (562 x 1000).jpg (203.88 KiB) Viewed 2362 times
Re: Clear out
if Derek wont have the sub ill be next in line
Re: Clear out
Have at it Paulb
It's bigger than I need
Thanks Andy for the exta info and good luck with the sale
Re: Clear out
Paulb if you still want it give me a shout.
You can collect it in Ranelagh or I can deliver it in Dublin.
0879807850
0879807850
