Arcam A 85, original box, remote control. Perfect condition.
With "processor mode". This is the setting that makes a (tape) input fixed gain so that the A85 can be used with AV amplifier.
No optional phono stage.
It can work as power amp (P85 specification).
Continuous Power Output Per Channel
Both channels driven 8 Ohms, 20Hz-20kHz 85W
Single channel 4 Ohms, 1kHz 140W
Distortion 8 Ohms, 80% power, 1kHz 0.005%
Line and Tape Inputs
Input sensitivity for rated 8 Ohms power output 700mV
Input impedance 22k Ohms
Signal to noise ratio* 105dB
Tone controls, max boost/cut +/-12dB
Preamplifier outputs
Nominal output level 700mV
Output impedance <3 Ohms
General
Power consumption (maximum) 800VA
Size W/D/H mm. inc. feet 430x330x102
Price: 350 Euro
Arcam A85 for sale (price negotiable)
