Intel server board S1200V3RPL
elaprince
Post by elaprince »
Hi guys
I bought S1200V3RPL server board and Xeon cpu to try MQ with Haswell hardware
I am having issues booting that board
Anyone has a advice on this subject?
I have CF card as a hard disk with OS on it
Ram is Apacer
When I plug it in and power the board I get no video from VGA out
I am getting blue light and green blinking for maybe 10 sec and then nothing with amber light
I am using pico psu
Thank you
Re: Intel server board S1200V3RPL
Prob cf card related
I think I remember CF required IDE-mode and most SATA will be default probably be AHCI-mode in BIOS.
Did you check?
is it posting bios?
Would have to do some work on Google but does the Xeon have onchip graphics, I think not but worth checking.
If not and the Server board does not have a graphics chip then you will need a basic graphics card to get going.
elaprince
Post by elaprince »
not posting bios
it has on board graphics with VGA out
Thank you all
I bought another PSU just to try it now I get beeps at least
1 then 5 then 4 then 4 again with amber light
elaprince
Post by elaprince »
as soon as I get bios somehow I will change it to IDE
but so far no luck
Thank you
elaprince
Post by elaprince »
1-5-4-4
Power control
fault (power good assertion
timeout).
Power good assertion timeout
Power unit
sensors report soft power control failure offset
I found this above
What that means????
elaprince
Post by elaprince »
Anyone can advise on that?
Thank you
Sounds like you need to try another ATX supply.
You either have a ground fault or bad power supply.
