Squeezebox gone a bit wonky??
Rocker
Post by Rocker »
My Squeezebox system is acting up. It plays 42 seconds of a song then restarts the same song until 42 seconds and restarts.....
I checked the settings, all seem fine, restored the settings to factory default, deleted the file index and recreated it etc. The problem is the same if I use the Duet remote, the Squeezebox software on my phone or iPeng on my iPad.
Not sure where to go to from here. Re-install Logitech Media Server???
All help/suggestions appreciated.
Beware of a thin chef!
Rocker
Re: Squeezebox gone a bit wonky??
Post by Rocker »
Technology!!!!
I selected the option "Clear library and rescan everything" again and the system is now working as normal.
No idea why it did not work first time around.
As I said at the beginning of this post, Technology!!!!
meep
Post by meep »
Good to hear you solved this.
I recall this happening to me a few years ago but cannot recall the solution.
I have 2x Radios and a Squeezebox 2 still running as well as a few 'virtual' squeezeboxes I run on a server to provide multi-zone audio. I really do like them and rue the day they die and I'll need to move Sonos or something.
