Daphile on a Raspberry Pi??
Rocker
Post by Rocker »
Is it possible [in other words easy] to run Daphile on a Raspberry Pi? What is the minimum RAM requirements to run Daphile? Thanks.
Beware of a thin chef!
Re: Daphile on a Raspberry Pi??
https://www.google.ie/url?sa=t&rct=j&q= ... 5890,d.ZGU
or
https://volumio.org/
raspberry pi or beaglebone black are great bang for buck solutions
randytsuch
Post by randytsuch »
Rocker wrote:Is it possible [in other words easy] to run Daphile on a Raspberry Pi? What is the minimum RAM requirements to run Daphile? Thanks.
Nope, Daphile only runs on PC. In the diyaudio thread, developer has said numerous times he wont' support other platforms, too much work for him.
I used this for a while.https://sites.google.com/site/picoreplayer/home
It runs the old squeezeserver stuff like Daphile, but you need a separate PC to be the server.
