Bootable Linux USB stick?
Rocker
Post by Rocker »
This question may be (1) idiotic or (2) already covered in other posts but is it possible to create a bootable Linux USB stick so that I could run my computer for music replay? Would a Linux OS 'see' my Windows 7 directory structure and hence my music files or would I need a separate hard disk drive for Linux files. The hard drive on my computer is about 500 Meg and I have slightly over 100 Meg free space. I could get a larger hard drive if it were possible to move my OS and files to it. Guidance is clearly needed guys and maybe some hand holding while I learn the system. Volunteers ?????
Beware of a thin chef!
Re: Bootable Linux USB stick?
agghh the lure of the dark side
best thing i can do is make you a 'daphile' usb stick and send it to you in the post :)
whats the spec of your pc or laptop just so i know what im dealing with
1 word - Daphile!
is the computer section becoming daphiled ?
sbgk wrote:is the computer section becoming daphiled ?
well we were calling it the gateway drug on sunday
will certainly suit some people that arent particularly looking for the bleeding edge
more like ease of use, sounds better than most players and its free
Claus
Post by Claus »
Can't get mqn to work on my nuc with the Hugo at the moment, so Daphile is very handy! And it sounds pretty good too...
Rocker
Post by Rocker »
nige2000 wrote:agghh the lure of the dark side
Thanks Nigel. From my researches I have concluded that Daphile works on a computer that is connected directly to the system and not as mine is [via a Sonos or Squeezebox wireless connection]. I have a volume control 'box' and am looking out for a computer that would run Daphile. Then a DAC, one of John Kenny's most likely, is needed and I am up and running. Steep learning curve? It is almost vertical but that is how it is. I will contact you when the required hardware has been sourced.
Rocker
Post by Rocker »
Claus, I saw your mini computer at Frans on Sunday. Impressive to say the least. I sent you a PM about this. I gather you were occupied on other demanding tasks. In your own time...... Thanks.
Claus
Post by Claus »
Sorry Tom, no pm in my inbox. Will pm you my number in case you want to have a chat....;)
Broadwell NUCs just being released at the mo...
