LP frames
LP frames
These can be quite hard to get.... but there's a shop in Liffey Valley - with branches in most shopping centres around the country called "Tiger" - they sell all sorts of crap...... anyway, they have LP frames in stock at €5 each.
Re: LP frames
Fran wrote:These can be quite hard to get.... but there's a shop in Liffey Valley - with branches in most shopping centres around the country called "Tiger" - they sell all sorts of crap...... anyway, they have LP frames in stock at €5 each.
They're in Rathmines as well... the old Extravison shop....
Re: LP frames
Thanks for that guys. I have one LP cover that I kept long after the vinyl was literally played to death [in my youth!] which I would like framed.
Re: LP frames
fergus wrote:Thanks for that guys. I have one LP cover that I kept long after the vinyl was literally played to death [in my youth!] which I would like framed.
Yeah some of the frames I've seen were just too dear but at a couple of euro (well 5!) it's worth doing. It was only after they took out the Christmas stock they brought in the LP frames. "Tiger" are a Danish chain that do cheap and cheerful stationary etc - a kind of small item IKEA! I like them, some of their stuff is very well designed.
Re: LP frames
I pass the Tiger shop on the bus on my way home from work I must pop in on Monday.
Re: LP frames
I'm a fan of Tiger, I'll have a look, they have a shop in White Water Shopping Centre Newbridge.
Re: LP frames
I found a Tiger shop today and made my purchase. Looks good!
