Speaker Cable Length?
sdiesel77
Post by sdiesel77 »
Hey Guys,
I was looking online to get some answers about the real effect of using different speaker cable length and there are a lot of different opinions on the topic.
What's yours? I have run blind tests on my system and couldn't hear the difference
Re: Speaker Cable Length?
sdiesel77 wrote:I have run blind tests on my system and couldn't hear the difference
There's your answer so!
FWIW, I've done the same myself and decided that it made no difference at the kind of lengths I was looking at. I suppose if one cable is 20m and the other is 20cm it might make a difference, but at normalish lengths I couldn't find an effect.
