KEF 104/2 need good home
I have a set of 104/2 that I have owned from new since1987 that need a new home. In reasonable condition with some marks on wood but nothing a good polish won't fix. Two 5 metre lengths of Naim NACA4 speaker cable included. Speaker cables have some replacement banana plugs but no discolouration of copper.
I have not replaced any cones or foam rings on speakers. Have spikes on speakers and rubber feet for use where spikes aren't suitable. I have original receipt and documentation somewhere in the attic but might have a job finding it. Looking for €400.
Also have a two tier black Target HiFi rack suitable for turntable with spikes supporting top shelf. €35 or thereabouts buys this.
Have photos but need some technical assistance to reduce size to add to post.
Re: KEF 104/2 need good home
Pixresizer is your friend and is free.retro252 wrote: Have photos but need some technical assistance to reduce size to add to post.
- Speakers
- IMG_20140818_194028.jpg (109.67 KiB) Viewed 2489 times
Hi, is this still available?
Yep - still sitting in roughly the same spot !
Thanks for the reply. Sorry, due to change of plan I withdraw my interest. GLWS.
Hi,
I might be interested in the rack. Can you tell me the dimensions please.
James
James
Hi James,
Stand is 51cm wide x 50cm deep x 40cm high external measurements including frame. Shelves are 47cm wide x 36 cm deep.
Thanks for the info on size. I will take it if still available. I will send you a PM tomorrow . I am situated in Dublin.retro252 wrote:Target HiFi rack suitable for turntable with spikes supporting top shelf. €35 or thereabouts buys this.
PM sent ...
