How to rescue flood damaged audio gear.
terrybites
Post by terrybites »
Can't vouch for the efficacy of the attached info but may be worth a go for any flood affected audio buffs!
http://www.trustmeimascientist.com/2012 ... udio-gear/
Re: How to rescue flood damaged audio gear.
Yeah, avoid corrosion by rinsing out quickly. Getting everything fully dry is an issue - a compressor to blow out water from under chips, and nook and crannies is a good way to go. If you could put it all in a sealed box with a couple of bags of rice for a dya or two, might help too.
Finally when you power up, make sure your breakers and ELCB are working right!! Turn it on with a brush handle!!!
