Are Wadia no longer doing CDP
HiFiFan
Post by HiFiFan »
Just browsing Wadia site today looking at Intuition 01 and no CDP anywhere. Have Wadia stopped making CDPs?
Re: Are Wadia no longer doing CDP
Wadia seem to have changed hands (and attitude) recently, so it wouldn't surprise me at all.
They probably read the "build a dedicated audio pc" thread here and just gave up.
all joking aside a audio pc build is probably the cheapest way to upgrade a digital system, the upgrades in pc audio seem to be similar to upgrading an amp/dac etc, and our pc builds over on the other thread have become more foolproof and stable once built and software is installed (unless someone does something mad) the more standardised builds are simple enough. hit the button to turn it on hit the button to turn it off and use jriver software and app software for ipad/ipod/android to control and select tracks.
like to hear one of these high end cdp vs the lastest wave of pc audio builds
HiFiFan
Post by HiFiFan »
Ivor wrote:They probably read the "build a dedicated audio pc" thread here and just gave up.
It is quite a thread
Claus
Post by Claus »
nige2000 wrote:all joking aside a audio pc build is probably the cheapest way to upgrade a digital system, the upgrades in pc audio seem to be similar to upgrading an amp/dac etc, and our pc builds over on the other thread have become more foolproof and stable once built and software is installed (unless someone does something mad) the more standardised builds are simple enough. hit the button to turn it on hit the button to turn it off and use jriver software and app software for ipad/ipod/android to control and select tracks.
Totally agree. Though there is a DAC/Interface factor to add to the PC playback equation as well, I can see the CDP loosing ground to streaming very fast. Especially when hi-res streaming becomes widely available....
jaybee
Post by jaybee »
can you roll a joint on a download though?
jaybee wrote:can you roll a joint on a download though?
Not that I would know but sure couldn't one use the mouse mat?
On a more serious note I would assume that unless they come up with a huge improvement in cd sound quality it will
be difficult for manufacturers to swim against the tide. Turntables I believe regardless if whether they sound better than dacs or fall behind will always have a following. Maybe cdp's have reached their peak in terms of development. It is just a case of whether they the medium is going to sustain interest in the long term. I think not simply because of the size and presentation of the packaging.
even with a CD case you get a one skinner.
Im sure you'll all manage without!!
think ye missed the point of a cdp though its a bit more than a flat surface
