Magnaplar Fix
DavidMc
Magnaplar Fix
Post by DavidMc »
A pair of Magnaplaner SMG up on adverts but high freq are gone on both pairs, are they fixable? Going for a song.
http://www.adverts.ie/230195/home-audio ... -speakers/
Re: Magnaplar Fix
Morkus beat you to it David....
FWIW, the answer is maybe. If its just a wiring issue.... but if its the actual ribbons gone I'd say no is the answer.
Sending you a PM about something else......
Fifthgear
Re: Magnaplar Fix
Post by Fifthgear »
Hey
They are fixable but you would need to send them to US:) They will make them look and sound brand new. But at the same price you can get a new pair. So is there a point fixing them? no!;)
I had a pair just sold two moths ago on adverts
